Date/Time: Mon, 23 Dec 2024 14:51:59 +0000
Appearance of Control Bar/ToolBar Buttons can now be Customized. Version 1303
View Count: 1858
[2015-10-02 20:30:39] |
In version 1303 it is now supported to customize a Control Bar / ToolBar button caption, description, color and image. This can be done by selecting Global Settings >> Customize Toolbars >> ToolBar #. Select the button in Selected ToolBar Commands. Press the Properties button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-06 20:12:26] |
ejtrader - Posts: 688 |
SC Team - Thanks for this nice addition. Wondering if any of this functionality (defining colors dynamically) can be extended to the Chart Shortcut items/buttons through ACSIL as well. The idea behind this - If there is any significance to the Shortcut menu/button - we can color/highlight them accordingly. Also this can be used to better group them as needed with respective colors. Thanks |
[2015-10-06 22:39:22] |
jimnovak - Posts: 42 |
thank you for much needed feature. now i have no excuse not to make money!!! but on a serious note many thanks.
