Date/Time: Tue, 15 Sep 2026 01:39:18 +0000
Connection Lost: 02Oct2015 at 2:35pmEST
View Count: 1025
| [2015-10-02 18:36:03] |
| User69055 - Posts: 23 |
Wondering if you guys are experiencing issues with connection. Let me know. Thanks
| [2015-10-02 18:48:57] |
We see you are using TransAct. Make sure you are on the current version of Sierra Chart. Other than this, refer to help topic 3.4 here: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
