Date/Time: Sun, 08 Sep 2024 01:45:46 +0000
CQG datefeed
View Count: 909
[2015-10-02 18:01:05] |
SgtJ - Posts: 154 |
Past 2 overnight sessions data has stopped flowing (between 1am-2am EST) despite the connectivity DF area remaining green. Nothing in the log either. SC version 1261
[2015-10-02 20:31:48] |
This is a CQG data feed problem. We will let them know about it. When you see this, reconnect to the data feed with the commands on the File menu.
