Date/Time: Mon, 23 Dec 2024 11:41:46 +0000
Need tutorial re: using Sierra's DOM
View Count: 874
[2015-10-02 15:14:06] |
User340788 - Posts: 3 |
How to use it- modifications. can it be static?- setting limit orders, as much as is available. Thanks |
[2015-10-02 16:55:28] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#TradeDOM For help with scaling Chart/Trade DOM refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-02 16:56:34
