Date/Time: Mon, 23 Dec 2024 11:19:57 +0000
Trade Activity Entries Deleted, but trade statistics stays
View Count: 1411
[2015-10-02 14:57:45] |
Viacheslav Malafeev - Posts: 88 |
Dear Support, When I delete a few trades in the Trade Activity Entries tab (or even the whole day), these entries disappear in Trade Activity Tab, but when I switch to Trades Tab or the chart itself, I find that the deleted trades are still there! I haven't come across this issue before. Any idea what is going on? |
[2015-10-02 16:43:18] |
This should not be a problem. When you do this, select Edit >> Refresh Log. After that the tabs after the Trade Activity tab will be updated. But this should happen automatically and we have verify this. Another thing you need to be aware of is that unless you delete "Fills", that will not have any effect on what is displayed on the tabs other than the Trade Activity tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-02 16:47:55
[2015-10-02 17:10:28] |
Thanks, that was the problem. For some reason I had "orders" showing only. |
