Date/Time: Mon, 23 Dec 2024 11:48:37 +0000
How to draw to the blank are on the chart
View Count: 705
[2015-10-02 12:50:29] |
User386687 - Posts: 53 |
How can I get an access to the area shown by the red box (for example to add lines and boxes to it) ?
Date Time Of Last Edit: 2015-10-02 12:51:19
2015-10-02_15-47-19.jpg / V - Attached On 2015-10-02 12:50:06 UTC - Size: 99.16 KB - 291 views |
[2015-10-02 17:32:56] |
You need to increase the Number of Forward Columns in Chart >> Chart Settings: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#NumForwardColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
