Date/Time: Mon, 23 Dec 2024 11:50:08 +0000
Trying to draw Midpoint HL Avg
View Count: 1158
[2015-10-02 11:55:10] |
User59072 - Posts: 3 |
Using Daily OHLC i can display the HL Avge line successfully this is based on the chart session times. I want to then apply this to a High/Low Time period. I tried used the High/Low time period and the extended version defining a time range intraday from which to calculate and display the HL Avg. So i added this study setting the time range. Then i based the Daily OHLC in settings on the study that High/Low for time period that sets the period. I have checked settings and nothing is displaying. Can this be done/achieved in this way? thanks |
[2015-10-02 17:24:18] |
You need to use the Study Subgraphs Average study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-02 17:58:23] |
does the job great - but is there a way to stair step it as it does in the Daily OHLC HL Avg - when i stair step this it stair steps over time as high and low shifts? thanks |
[2015-10-02 18:01:40] |
No.
[2015-10-02 18:07:37] |
ok so that would have to be written as a custom study thanks for help just wanted to make sure i wasnt'd missing anything and i did search support for similar question. Hopefully it will help others |
