Date/Time: Mon, 23 Dec 2024 11:21:51 +0000
5th band on VWAP
View Count: 876
[2015-10-02 11:44:42] |
Guilherme - Posts: 66 |
Is there a way to insert a 5th band on VWAP? Actually, if there was a way to specify the Std Deviation for each band instead of between them, then that would not be necessary for me. Any hint?
[2015-10-02 17:20:51] |
A fifth set of bands is not supported. We will make the Standard Deviation multipliers programmable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
