Date/Time: Mon, 23 Dec 2024 13:22:06 +0000
Bid/Ask Driven Chart
View Count: 822
[2015-10-02 10:46:48] |
User760942 - Posts: 120 |
Hi SC, Is it possible to make a chart that makes a new bar anytime the Bid or Ask price changes? thanks |
[2015-10-02 17:22:13] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_RecordingModes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-05 23:34:52] |
Cool, that works, thanks for the info!
