Date/Time: Mon, 23 Dec 2024 12:00:44 +0000
Region Data Line -Cannot turn off TPO study
View Count: 1053
[2015-10-01 21:27:54]
vectorTrader - Posts: 86
I am trying to turn off the TPO study or at least shorten the name of the study to display other more pertinent information. Can you look as to why it doesn't turn off when its option is deselected in the subgraph menus.
[2015-10-02 02:17:57]
In the next release there will be support for setting the Short Name in the Study Settings window for the TPO Profile Chart study that you can use to set a shorter name.
But in general, what you need to do is go to Global Settings >> Customize Chart Header to customize what is displayed along the top line of the TPO Profile Chart.
This is what controls it and not the Study Settings which normally have an effect on the Region Data Line.
Date Time Of Last Edit: 2015-10-02 02:18:37
