Date/Time: Mon, 23 Dec 2024 11:27:08 +0000
Can this be done on SC?
View Count: 821
[2015-10-01 19:57:53] |
User28914 - Posts: 87 |
I'd like to write the high and low of the previous bar on the chart - how do you accomplish this?
[2015-10-01 20:02:50] |
It's easy to write value from the current bar but I can't see how to do the previous bar.
[2015-10-01 21:24:07] |
i960 - Posts: 360 |
Most likely this: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s294
[2015-10-02 03:57:01] |
We assume you want to display this as text? If so, use the Text Display for Study study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s334 You will need to add 2 instances of the study. One to reference the High and one to reference the Low of the main price graph. Set the Subgraph Columns Back Input to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-02 03:57:23
