Date/Time: Mon, 23 Dec 2024 11:53:40 +0000
Attach / Detach Charts
View Count: 970
[2015-10-01 17:25:00]
AP - Posts: 117
While detaching is working.
Attaching it back does not and it instead detaches some other chart from some other chart book altogether.
Do you know why does this happen?
[2015-10-01 17:33:39]
Make sure you use the Window >> Attach/Detach command directly on the detached window. Here is the documentation:
https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html
[2015-10-01 18:17:59]
AP - Posts: 117
That is what I thought - but the problem is I cannot see the File, Edit....Windows Menu on the detached chart window itself.
[2015-10-01 18:49:22]
OK so it sounds like you have hidden the menu.
Follow the instructions here to show the menu:
https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#ShowMenu
[2015-10-01 19:07:28]
AP - Posts: 117
That worked - THANK YOU!
