Date/Time: Mon, 23 Dec 2024 11:57:24 +0000
Gene Sheldon
View Count: 921
[2015-10-01 12:19:11] |
User72965 - Posts: 115 |
I Floated the tool bar #1 And can't put it back under the menu bar ?????? I can only close it . Then only get it by going to window select tool bar #1 > Brings it up in "float" only ?? How do I correct this ??? Gene :)http://www.sierrachart.com/image.php?l=1443701894896.png Sent an image ~~~~ |
[2015-10-01 14:19:31] |
SC Developer - David - Posts: 660 |
You need to right click on toolbar and select "Attach to top" in context menu.
[2015-10-01 17:54:53] |
Only wayI can get it back is to drag float over HAND And right double click . puts it back .. I follow your instructoins . Attach in context menu ... I do not get. What's context menu ????????? Also >> NOw got this HAND bar under tool bar. ike to get rid of it ... Thx Gene . http://www.sierrachart.com/image.php?l=1443722067489.png |
[2015-10-01 18:30:59] |
I figured out "Hand" It's the "description" of what's selected in The Short-cut Menu. Do we want to hide it ?? Can we ?? Gene |
[2015-10-01 19:05:02] |
There have been changes to the Control Bar. You are running an older version. You need to update by following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-02 04:12:37] |
Here is the documentation to work with the new ToolBar in the latest release of Sierra Chart: http://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#ToolBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
