Date/Time: Mon, 23 Dec 2024 12:16:23 +0000
Check/ Uncheck Button for Studies
View Count: 720
[2015-10-01 05:02:14]
nicktrader - Posts: 717
It would be very helpful if the Study Settings contains an Check/ Uncheck Button (or even two).
The Daily Pivot is a good example for that. Each level and each field is checked (even the hidden and unsual levels). If you want only some levels you have to clear all other not needed levels/ fields. It takes a lot of time.
Here in that case a Check/ Uncheck Button only for all fields for each level + a Check/ Uncheck Button for all levels/ fields would be very helpful.
imageCheck-Uncheck All Button.png / V - Attached On 2015-10-01 04:52:47 UTC - Size: 53.07 KB - 309 views
