Date/Time: Mon, 23 Dec 2024 11:57:32 +0000
Two symbols in a window
View Count: 769
[2015-09-30 17:21:43] |
User424274 - Posts: 6 |
Can you have two of the same symbols in a window so you can show one as candlesticks and the other one as a line on close?
[2015-09-30 17:51:53] |
Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#OverlayingMultipleSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-30 17:51:54] |
