Date/Time: Sun, 08 Sep 2024 00:06:39 +0000
1300 text color for TVW and CVW values
View Count: 980
[2015-09-29 21:15:54] |
User35525 - Posts: 181 |
Since updating from 1296 to 1300, the text background for Tool Values Window entries and Chart Value Windows entries is "black", and I'm not sure how to change the font color. Please see the attachment.
Date Time Of Last Edit: 2015-09-29 21:16:28
Private File |
[2015-09-29 22:13:24] |
The problem looks to be different. Scroll through that Chart Values window and see if there is any row name which is very wide causing the values to not be visible.
[2015-09-29 22:25:58] |
Yes, I did have a very wide entry on one line, so just now removed all studies (clean chart), but the problem persists. I can stretch the window to make it wider, and that helps so I can see all the values that were missing from the screenshot I sent earlier. But if I then shrink the window, the values are missing again. I just loaded a historical chart, and the only thing in my TVW is Y, Price Chg, Open, High, Low, Last, Volume, OpenInt, Bid Vol, and Ask Vol. Is there an issue that would cause the "Y" field to be very wide? Or perhaps the chart name of "CL.20151100.CME_NY Daily #1()", which is suspiciously about the same width as the first field (the one containing the column names of "Price Chg, Open, High, etc". --Ted |
[2015-09-29 22:52:15] |
This probably relates to changes that were recently made to fix a problem. We are looking into it now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
