Date/Time: Mon, 23 Dec 2024 12:08:47 +0000
CROSS HAIR ACROSS MULTIPLE CHARTS
View Count: 1125
[2015-09-29 20:15:23] |
User195549 - Posts: 2 |
I AM LOOKING AT 4 CHARTS AND WOULD LIKE TO BE ABLE TO SEE THE CROSS HAIR ON ALL CHARTS. IF I AM LOOKING AT CHART A IS WILL SHOW ME WHERE THAT BAR IS ON CHART C OR D.. CAN ANYONE TELL ME HOW TO GET THIS FUNCTION TO WORK.
[2015-09-30 04:31:31] |
This feature is called the Global Cursor and this documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CompactToolValuesWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-30 04:31:55
