Date/Time: Sun, 08 Sep 2024 00:19:35 +0000
Tirggered Trail Stop
View Count: 717
[2015-09-28 21:10:51] |
JRA - Posts: 97 |
I am trying to set up a trigered trail stop, and the trigger offset and trail offset keep changing their values to the same value as the stop offset. No matter if I put them manual by keyboard or by the arrows, once I set the triggered offset and go ahead to set the trail ofsset the trigger offset change back to the same value as the stop offset and the same happens with the trail offset. Any help? |
[2015-09-28 21:19:12] |
We apologize for this. We are going to immediately take care of this. The relates to recent changes to the Trade Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 01:07:47] |
This is now solved. Update Sierra Chart by selecting Help >> Download Prerelease.
