Date/Time: Sun, 08 Sep 2024 00:22:16 +0000
Remote server
View Count: 846
[2015-09-28 20:23:46] |
User19479 - Posts: 25 |
How can I use SeirraChart on remote server and my local PC at same time? also how to use two instances ? I trade Bitcoin, but cannot find datafeed for stocks. |
[2015-09-28 21:34:21] |
You just simply need to install another copy of Sierra Chart on whatever system that you require. Use the same Account Name and Password. For US stock data, use this data feeds: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-28 21:34:37
[2015-09-28 21:47:37] |
how to synchronize chartbooks between remote server and local PC? Local SC is installed on Mac with CrossOver app. No chartbook on remote server |
[2015-09-29 03:19:52] |
The only way to "synchronize" Chartbooks between copies of Sierra Chart is to manually copy the Chartbook. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
