Date/Time: Thu, 17 Sep 2026 20:35:59 +0000
Value Chart Levels Study
View Count: 2607
[2015-09-28 16:54:28]
User296494 - Posts: 2
I have added this study, but it does not appear to populate correctly. The study appears in region 5, but is only showing horizontal lines. There are no bars or candles populating the study. Have tried many items in the setting, but it still will not display correctly.
[2015-09-28 18:44:24]
Sawtooth - Posts: 4354
Use the Value Chart study for bars or candles, and use the Value Chart Levels study in the same chart region if you want OB/OS lines.
[2015-09-29 06:00:17]
Thank you. It's working now. I didn't realize the value charts and the value chart levels were a separate identity.
With SC alerts at the levels, could you give me a brief formula that will alert at the + Moderate level (+4), + Significant (+8) and also at the - Moderate (-4) and -Significant (-8) level. Thank you.
[2015-09-29 13:55:25]
Try this:
=OR(AND(ID2.SG1[-1]>ID1.SG4[-1],ID1.SG4>ID2.SG1),
AND(ID2.SG2[-1]>ID1.SG4[-1],ID1.SG4>ID2.SG2),
AND(ID2.SG4[-1]<ID1.SG4[-1],ID1.SG4<ID2.SG4),
AND(ID2.SG5[-1]<ID1.SG4[-1],ID1.SG4<ID2.SG5))
where the Value Chart study is ID1, and the Value Chart Levels study is ID2.
[2015-09-29 17:55:58]
Refer to the documentation here about Study Alerts:
https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html
Date Time Of Last Edit: 2015-09-29 17:56:10
