Date/Time: Fri, 18 Oct 2024 04:02:25 +0000
Mini LMAX
View Count: 764
[2015-09-28 16:31:17] |
gomifromparis - Posts: 244 |
Hi, There is the Mini DAX on LMAX, but I couldn't find the mini SP500. |
[2015-09-28 17:46:08] |
We will need to add this symbol.
[2015-09-28 17:54:02] |
We have added this symbol. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Data for this symbol will be available before the end of the day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
