Date/Time: Fri, 18 Oct 2024 03:41:41 +0000
Data for symbol SSE not loading today..
View Count: 777
[2015-09-28 16:11:46] |
The Stealthy Trader - Posts: 180 |
Hi, it's 9/28 12:10 EST and I've tried everything(reload, delete/reload) for symbol SSE and nothing shows up..yet on another platform, it's loading fine. Please advise basis the time indicated above. Thanks, Jon |
[2015-09-28 17:27:20] |
We see you are using TD Ameritrade. So the chart is completely blank? Go to the chart and select Edit >> Delete All Data and Download. If you still have a problem provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
