Date/Time: Sun, 08 Sep 2024 01:43:27 +0000
Charts Tagged
View Count: 739
[2015-09-28 04:51:56] |
User673725 - Posts: 12 |
The range of feeds available to my account seems to have changed. Previously we had bonds, metals and currencies, but recently this seems to have changed. I checked for the latest version and down loaded that only to find that many of the feeds I was looking for had gone !! When I try to update some of my old chart books the log says the feed or account has been tagged. Can you help please. thanks James |
[2015-09-28 05:57:34] |
Follow the instructions linked from the page here: https://www.sierrachart.com/index.php?page=doc/data.php#Services To use the particular Data or Trading service that you want. You have access to all of them. The particular symbols you see listed in File >> Find Symbol is different for each of them. In regards to "tagged" this is an unrelated message relating to studies: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#ReferencesOtherChartsTagging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-28 05:58:25
