Date/Time: Sat, 23 Nov 2024 04:00:09 +0000
Out of memory error
View Count: 2217
[2013-06-17 13:20:38] |
RPinCAR - Posts: 27 |
Downloaded new version today. Was changing a value in a spreadsheet, and the program started looping and saying Out of memory. Would not allow me to copy/send log. Looked like MS NET problem. I was able to save their error. Cannot open program at all. Thanks EDIT IT NOW HAPPENS TO MY LAPTOP WITHOUT THE NEW VERSION BEING LOADED. EDIT 2: I believe it is a DTN IQ issue Date Time Of Last Edit: 2013-06-17 14:24:15
Net error.txt - Attached On 2013-06-17 13:20:20 UTC - Size: 3.49 KB - 791 views |
[2013-06-17 17:11:39] |
This is what we have discovered: This morning IQ Feed has transmitted errors on many of their symbols which are way off price. This is causing problems with studies like the TPO Profile Chart study and the Volume by Price study to allocate huge amounts of memory. These studies do have the ability to manage this type of problem but this error is so significant that it is still causing excessive memory use and causing Sierra Chart to freeze. This is the procedure to correct the problem: 1. Terminate or restart Sierra Chart. 2. Do not open any of your Chartbooks. If you have Chartbooks set to automatically open, then quickly go to Global Settings >> General Settings and remove all the Chartbooks from the Files To Open On Startup list. Press OK. 3. Go to File >> Find Symbol and open an Intraday chart for each of the symbols you have Intraday charts for in your Chartbooks. 4. Look at the charts. If there is a data error, it will be very obvious. Right-click before that data error and select Delete Data and Download. Press Yes to confirm. You might need to scroll back the chart in time to spot the data error. 5.Once all of the data errors are corrected, you can then open your Chartbooks without a problem. 6. Let us know if you need more help. We do apologize for this, but this is an unexpected issue have to do with bad IQFeed data. It has nothing to do with the new Sierra Chart version. If you updated, it is merely coincidental that this problem has occurred today. It is due to an IQ feed data error. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-17 17:32:03
[2013-06-17 17:19:25] |
Would not be easier to rename the chart file before logging on? I don't think I can move that fast before it crashes. Ron |
[2013-06-17 17:31:27] |
That will work as well.
