Date/Time: Sun, 08 Sep 2024 01:32:17 +0000
AutoTrade Sys order size resetting back to 1
View Count: 789
[2015-09-27 22:16:10] |
User170575 - Posts: 221 |
Hi, When running a backtest in the autotrade system the order size is reset to 1 at the beginning of the scan(in the trade window attached to the chart)? Is there another place to set the trade size? Thanks for all your help, Cy |
[2015-09-27 22:38:33] |
Is this a spreadsheet or ACSIL based trading system?
[2015-09-28 00:11:44] |
Spreadsheet
[2015-09-28 01:17:39] |
You need to set the Order Quantity cell: http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#CellJ26 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
