Date/Time: Tue, 21 Jul 2026 06:17:04 +0000
Intraday chart missing data
View Count: 951
| [2015-09-27 22:11:34] |
| User417540 - Posts: 13 |
Hi. Using CQG/AMP intraday chart does not appear to be showing all data? Please see attached chart. http://www.sierrachart.com/image.php?l=1443391681980.png |
| [2015-09-28 01:15:26] |
There was a CQG data feed problem which is the cause of this issue. We will have a new release of Sierra Chart out this week which will support historical data from CQG and they should have the data. So you will be able to recover it at that time. Please check back in about two or three days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
