Date/Time: Sat, 23 Nov 2024 03:25:01 +0000
SC, packpage 3 to 5
View Count: 1343
[2013-06-17 13:17:48] |
abrown8703 - Posts: 64 |
SC, I currently have package 3 paid up until 9/29. However, I am evaluating a strategy that requires package 5. I need 5 days or so to determine if the upgrade to package 5 is necessary. However, you only allow a all or nothing upgrade[/b]. Can you adjust my account for 5 days of package 5, which will revert back to 3. Obviously using the time I've already paid for? To your continued success! Date Time Of Last Edit: 2013-06-17 13:23:17
ScreenClip.png / V - Attached On 2013-06-17 13:23:09 UTC - Size: 8.7 KB - 486 views |
[2013-06-17 18:27:09] |
Your account has been provided access to package 5 for 10 days.
