Date/Time: Sun, 08 Sep 2024 01:49:35 +0000
RSI
View Count: 824
[2015-09-26 19:15:45] |
gmorgan111 - Posts: 121 |
I have my RSI set up on my 3 min chart trading the 30yr and for some reason the RSI is bottoming out on zero before it has a chance to close. Is this a scaling issue? I have it set on the main price chart with a 2 length. Thanks |
[2015-09-26 21:46:19] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-27 22:15:22] |
Here is the copy of my chart per your request. The scale seems to be weighted to the zero. http://www.sierrachart.com/image.php?l=1443392005258.png Thanks |
[2015-09-27 22:41:41] |
You need to increase the RSI Length Input setting for that study to avoid this effect. From testing you do not really want to go below 4. The calculation that Sierra Chart has for RSI is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
