Date/Time: Sun, 08 Sep 2024 01:45:43 +0000
Ability to do composite and range profiles based on time instead of volume.
View Count: 885
[2015-09-26 14:11:31] |
User34383 - Posts: 1 |
Hi, I'm trading using composite and range profiles based on volume, using the L2ST framework. However, there are some instruments in my data feed where volume data is simply not available, and for these ones I'd like to be able to draw range profiles and display composite, based on TPO (time) instead of volume. I am aware this is not accurate as a volume based profile is, but for me it's better than no profile at all :) I don't need any TPO features like showing letters, I just need to be able to highlight a 68% VA with POC, VAL and VAH. All in all, similar features to the existing Volume At Price studie. I've played around with the existing TPO studies, but none of them fits my needs currently. And another note. I'd like the ability to keep a thin border always visible around my drawn profiles... I tend to lose sight of small profiles :) Thanks! Date Time Of Last Edit: 2015-09-26 14:12:24
