Date/Time: Mon, 23 Dec 2024 08:15:11 +0000
Chart lagging behind of trade service datafeed
View Count: 968
[2015-09-26 02:45:30] |
User567294 - Posts: 47 |
I am using AMP/TTnet datafeed for trading, and sierra chart datafeed as my chart display. the issues is my trading order already been filled right before chart display at least 1 or 2 seconds. how can I solve this problem? thanks Rex. |
[2015-09-26 03:02:34] |
So you are saying the Sierra Chart Exchange Data Feed is lagging? Refer to help topic 4 to see if anything there helps: Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html One thing that will reduce bandwidth usage is to not use the market depth features for a particular symbol to stop the market depth updates. No matter how good it data feed is, if the time it takes for data to arrive from the server to your location is in the hundreds of milliseconds, and if the bandwidth is limited, if the market is very active and there is market depth data being received, some amount of lagging is going to be inevitable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-26 03:08:28
