Date/Time: Sun, 08 Sep 2024 01:36:22 +0000
Renko
View Count: 799
[2015-09-25 21:48:29] |
Crtfyd - Posts: 278 |
vs 1282 I have a intraday chart (1 min)candlesticks. I am trying to change to Renko or Renko with wicks but cannot. After I "apply" or "ok" it switches back to candlesticks. Won't stick on any other "Graph draw type" I restarted, and the same. Problem with this version? |
[2015-09-26 02:02:40] |
Are you referring to the Renko Graph Draw Types in Chart >> Chart Settings?
[2015-09-26 02:39:21] |
yes
[2015-09-27 21:51:39] |
never mind. I see that chart has to be tics for Renko. Should've see this. Thx |
