Date/Time: Mon, 23 Dec 2024 08:33:20 +0000
Renko reversal open
View Count: 1960
[2015-09-25 15:47:08]
Peder - Posts: 1
I am using renko bars with 5 ticks with wicks. The reversal bars are 10 ticks. When it draws the reversal bar, it only draws the colored part as 5 ticks from the previous bars high/low. How can I make the colored part of the reversal bar the full 10 ticks? For example, green up is 5 ticks. Red reversal is 5 ticks long from low of previous green bar. I want it to be 10 ticks from close of previous bard. Really I just want the open of the bar to be the same as the close of the previous bar. "Show real open" doesn't work because the open isn't always the close of the previous bar.
[2015-09-25 18:15:56]
Make sure you are using the Bar Period Type >> Renko Bar setting in Chart >> Chart Settings:
https://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html
Renko bars are fully documented on that page. It sounds like you are looking for nonstandard functionality. Possibly the Flex Renko Bars will accomplish what you want.
Otherwise, we cannot provide any help with this at all. Renko bars are not going to work any different than the functionality provided and we are not going to add anything new with them.
Date Time Of Last Edit: 2015-09-25 18:18:21
