Date/Time: Mon, 23 Dec 2024 08:40:55 +0000
Cant find symbols in SC Forex Data (FXCM)
View Count: 888
[2015-09-25 13:16:31] |
buylosellhi - Posts: 60 |
I'm not able to see any symbols using SC Forex Data (FXCM) when I select File-->Find Symbol. Could you please help me with this. Thanks
No FXCM Symbols.PNG / V - Attached On 2015-09-25 13:16:17 UTC - Size: 19.46 KB - 285 views |
[2015-09-25 18:06:47] |
Follow the instructions here to update the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
