Date/Time: Sun, 08 Sep 2024 01:34:17 +0000
volume number on a chart dom: how to change color and size text ?
View Count: 1464
[2015-09-25 10:13:42] |
sierra28 - Posts: 120 |
difficult to see it and gradiant color of depth is no very well
Date Time Of Last Edit: 2015-09-25 10:14:53
[2015-09-25 19:51:40] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ChartTradingCustomizingGraphics.php The color setting which controls the text for the DOM Graph is Trade DOM Last Price/Quantity Text. The page explains how to change the font size and other properties. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-28 07:01:47] |
sorry but i don't find anything to increase width of numbers in chart dom (percentages, V.ask total V.bid total and volume at each price level). you give me how to change on a chart dom but i want when chart trading mode is off (cf capture) |
[2015-09-28 08:11:21] |
You need to increase the Chart Text Font Size as explained here: https://www.sierrachart.com/index.php?page=doc/doc_ChartTradingCustomizingGraphics.php#FontSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-28 08:11:35
