Date/Time: Mon, 23 Dec 2024 08:24:55 +0000
Is that possible to get access to the data of Chinese trading market?
View Count: 983
[2015-09-24 20:45:55] |
User327075 - Posts: 1 |
As the subject described, is there any feeds I can use to get access to the data of Chinese trading market? I appreciate all your help.
[2015-09-25 04:58:27] |
The only supported Data or Trading service that may have this data would be Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/IB.php So please check with Interactive Brokers. Sierra Chart also supports the DTC Protocol: http://dtcprotocol.org So it is possible for a Data service providing this data to adopt this protocol and Sierra Chart will be compatible with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
