Date/Time: Mon, 23 Dec 2024 08:47:54 +0000
can't connect to Rithmic
View Count: 797
[2015-09-24 14:01:04]
User948258 - Posts: 4
Pls look at the log. I can't connect to Rithmic on my home computer. It works at my office on windows8 but at home ,on my old computer, I have still windows XP.
Are the windows XP the problem? I believe that Rithmic works on win7 and above (dunno for data feed).
thank you
I
a
Private File
[2015-09-24 17:26:54]
Yes, it is necessary to be using Windows 7 or higher when using Rithmic to be able to connect. This is necessary because the Rithmic software requires it.
Date Time Of Last Edit: 2015-09-24 18:25:24
