Date/Time: Mon, 23 Dec 2024 08:52:04 +0000
NO DATA ON ONE CHART.. BAR NOT MOVING
View Count: 800
[2015-09-24 13:21:02] |
User195549 - Posts: 2 |
I HAVE A 2 TICK ES CHART THAT IS NOT MOVING. NO PRICE MOVEMENT BUT THE OTHER 3 CHARTS ARE MOVING. DO NOT KNOW WHAT TO DO. ALSO TRYING TO GET CROSS HAIRS TO SPAN ACROSS ALL CHARTS AS I LOOK AT ONE SPECIFIC LOCATION ON A CHART.
[2015-09-24 17:32:20] |
For the chart updating problem, refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html To use the Chart Values across all charts, refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor The feature is called the "Global Cursor". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
