Date/Time: Mon, 28 Oct 2024 08:57:49 +0000
Draw Volume Profile Suggestion
View Count: 1258
[2015-09-23 20:36:53] |
User615056 - Posts: 12 |
Hi Guys. Would it be possible to include the volume average price for the drawn profile. It would be a simple extended line. Nothing fancy. It would just show you the average weighted volume for that drawn profile. It could be turned off or on. User choice. Thank you for your consideration. Date Time Of Last Edit: 2015-09-24 09:37:27
[2015-09-24 00:42:51] |
vectorTrader - Posts: 86 |
+1 , funny I requested it right about the same time. Or for that matter, just be able to overlay the latest value of the vwap from another study and chart
[2015-09-24 02:49:46] |
Do you mean the Volume Weighted Average Price?
[2015-09-24 02:58:10] |
Yes.Yes and Yes.. Long day sorry for the mixup.
[2015-09-24 03:41:11] |
OK, we will try to get this done in the next few days.
[2015-09-24 06:07:42] |
crazybears - Posts: 314 |
+ 1 and others Volume by Price |
[2015-09-29 21:30:44] |
Hello Support Team. Was there any consideration to add this ability? It is very useful for those of us that are always drawing out the profile. Thank you. |
[2015-09-30 04:56:56] |
This is in prerelease 1301 of Sierra Chart. Here are instructions to use it: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#CalculatingDisplayingDevelopingPOC_VAH_VWAP Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-30 08:49:25] |
Hi. Almost there :) It should be a straight line across the profile. And its drawing the line in last profile straight up at the very end. http://www.sierrachart.com/image.php?l=144360271174.png |
[2015-09-30 09:26:33] |
Are these Volume Profiles manually drawn on the chart?
[2015-09-30 10:34:54] |
Yes by using the Draw Volume Profile.
[2015-10-01 03:18:37] |
eagle - Posts: 92 |
I like it not being a straight line across the chart. In other words, I like the VWAP displaying each bars value. (That's partly because I already have a custom study that draws the straight line for the latest VWAP value.) The image link is a chart with the Volume By Price study added. The VWAP line is going straight up on the current bar. http://www.sierrachart.com/image.php?l=1443669153219.png Actually, it's not the current bar. Looks like after the VWAP goes straight up, the VWAP stops updating. Date Time Of Last Edit: 2015-10-01 03:21:23
[2015-10-01 19:42:58] |
OK we are checking on this. The Volume Weighted Average Price line will be displayed always as a developing line and not a horizontal line which is a constant value during the duration of the volume profile. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-25 13:27:55] |
Guilherme - Posts: 66 |
This is really impressive. Never seen before such a responsive development team as Sierra's! Just one little sugestion about this. It was really hard for me to find out where to enable the VWAP visualization, since the "Draw Mode" in the tool setting does not mention it, only mention POC, VAH and VAL.
[2016-01-25 23:15:57] |
We will update those input settings. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#CalculatingDisplayingDevelopingPOC_VAH_VWAP Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
