Date/Time: Fri, 18 Oct 2024 05:45:30 +0000
Changed the time zone under "Global Settings" and the feed has stopped
View Count: 670
[2015-09-23 16:43:23] |
User170575 - Posts: 221 |
Hi, Changed the global setting for the time zone and my feed has stopped. Many thanks, Cy |
[2015-09-23 17:13:12] |
This has to do with the Session Times in the chart. Refer to help topic 3.3: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.3 If that does not apply, then refer to help topic 3.4: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
