Date/Time: Sun, 08 Sep 2024 02:17:59 +0000
Не отображается открытая позиция
View Count: 690
[2015-09-23 14:26:37] |
nick762 - Posts: 11 |
Почему-то на графике M6E не отображается открытая позиция. Причем на остальных графиках все нормально отображается. Подскажите в чем может быть дело. |
[2015-09-23 17:50:14] |
There is a problem with the internal Trade Position Average Price which is being used: The solution to this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed Specifically what you need to do is follow the instructions here to clear the non-simulated Trade Activity data for the Symbol and Trade Account: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
