Date/Time: Fri, 18 Oct 2024 06:39:24 +0000
TD-Ameritrade Indexes
View Count: 697
[2015-09-23 12:29:38] |
User170575 - Posts: 221 |
Good morning, TD's indexes have to have a "$" in front of the ticker which is what I put into a QB. It seems the price is not the same in SC...Example $IXE and $XAL. Is there another way to do this in SC? Thanks again, Cy |
[2015-09-23 13:03:21] |
plz cancel that---I think I will use the "sum all charts" study---very cool thx |
[2015-09-23 17:14:21] |
We are not totally sure but we do not think those indices are going to work with the connection that Sierra Chart uses to TD Ameritrade. You can use the Sierra Chart Exchange Data Feed for the cash indices: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 17:14:38
