Date/Time: Mon, 23 Dec 2024 07:47:49 +0000
Copy of SierraChart application
View Count: 680
[2015-09-22 12:31:05]
User742670 - Posts: 43
Hi guys,
Is there any way to copy all settings I mean all to another PC.I have Sierra on two computers but when I copy the all customized version to my other PC the background is different same as trade lines,candle stick bars colors etc..
I also tried to download the version which I use on the original PC to the new one which is version 1276 then I just replaced the entire folder SierraChart on the C:\ with that customized Sierra which dint help either.
I know that was possible in the past but I am not successful now.
Many thanks for your support!
P.S. I have rally no time to play with all the settings :-)
Many thanks guys!
David
[2015-09-22 14:40:29]
This is straightforward and you should not have any trouble with this.
The instructions are here:
Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html
