Date/Time: Mon, 23 Dec 2024 08:07:30 +0000
Orders and Positions suggestions
View Count: 723
[2015-09-22 11:44:42] |
phaedonk - Posts: 352 |
1) Column that shows in ticks how far the entry is (sortable). When there are many orders waiting to trigger, it really helps to see at a glance which one is closer to triggering. Would make trade/risk management much easier. 2) Open a chart for specific order, instead of searching for it in my chartbooks. Be able to link window to chart. (this suggestion also holds for the Trade Stats for Charts window) 3) Want to be able to see only parent orders, not all the clutter with child orders that have yet to trigger. Maybe use a tree-like structure and a plus sign. |
[2015-09-22 16:52:05] |
1. This is not the kind of functionality we would ever add to that window. 2. We will see about this. 3. This will not be added. Something like this might be considered much later on. But not now. In general we are not accepting new suggestions at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-22 17:17:41] |
Ok thanks. Regarding 1, I would probably pay for if someone could program this. Right now, I have to cycle through ten live orders and see which are closest to triggering, maybe cancel some so I'm not over exposed.
