Date/Time: Mon, 23 Dec 2024 07:20:18 +0000
2015 Volume Profile
View Count: 756
[2015-09-22 08:59:26]
User78442 - Posts: 260
Hi, I'm having problems putting a 2015 (start 01/01/2015) profile on Intraday Charts (240m-15m). The profile is OK on daily charts but only seems to load a portion of the volume on the minute charts? The Intraday settings for the data feed (SC) is 400 days (Tick & Minute) and the enclosed 240m chart loads 400 days. Any ideas?
imageFXZ15 [M] 240 Min #12 2015-09-22 09_58_50.054.png / V - Attached On 2015-09-22 08:58:55 UTC - Size: 41.58 KB - 317 views
[2015-09-22 18:21:35]
You need to set the chart to be a Continuous Futures Contract chart:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html
Apply the Volume study and set the chart bars to 1 hour per bar, and scroll through all the way to the beginning of 2015 and make sure all the data is there.
