Date/Time: Mon, 23 Dec 2024 07:30:04 +0000
[User Discussion] - Delta divergence
View Count: 2813
[2015-09-22 07:09:21]
Forward - Posts: 65
Hello , i am searching for " Delta Divergence Indicator " formula.
It is in the " Add Custom Study " list.
Which is the exact frmula ?
Thank you
[2015-09-22 21:32:19]
CustomIndicators - Posts: 126
Please follow this link. On the first post, there is attached a c++ file for this indicator, as well as its DLL.
https://www.sierrachart.com/supportboard/showthread.php?t=35090
I couldn't find it in my SC program even though I update frequently, so I hope this helps if you are in the same boat.
Date Time Of Last Edit: 2015-09-22 21:33:17
