Date/Time: Sat, 23 Nov 2024 03:24:49 +0000
How to have two axes?
View Count: 2322
[2013-06-16 20:35:44] |
keymoo - Posts: 9 |
I have a chart with ATR and volume at the bottom. I want the ATR scale on the y axis on the left side of the chart and the volume scale on the right side. Is it possible to do that? Here's my chart now: http://www.sierrachart.com/image.php?l=1371414925235.png |
[2013-06-16 21:51:16] |
Yes. Please see: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#LeftSideScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-17 09:03:47] |
keymoo - Posts: 9 |
Thanks, when I do this, I cannot have Volume on the right side because the scale of the ATR sends the plot to 0. Also, if I plot the Volume on the left side, the values are truncated. See images Truncated vols http://www.sierrachart.com/image.php?l=137145946631.png Volume on the right side, minimizes ATR http://www.sierrachart.com/image.php?l=1371459820585.png |
[2013-06-17 14:58:12] |
Vergina Star - Posts: 9 |
Keymoo, You can have Volume on the right side. Make Volume the first study on the graph (ID:1). Then in the ATR settings. Make the Scale "Independent. Study Settings >> Settings and Inputs Tab >> Scale Button >> Scale Range >> Independent. I just tried it on a different symbol but it should work the same for QNG http://www.sierrachart.com/image.php?l=1371480954409.png |
