Date/Time: Sun, 08 Sep 2024 01:35:30 +0000
Draw Text value from Spreadsheet
View Count: 980
[2015-09-22 06:25:22] |
User80177 - Posts: 29 |
Hi, Is there a way to draw a text value from a cell in the old spreadsheet to a high or low of a bar on the chart? Thanks |
[2015-09-22 18:17:09] |
Yes. You can use the Value on High or Value on Low Draw Styles: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-22 22:11:38] |
Sawtooth - Posts: 4083 |
The Value on High and Value on Low Draw Styles will only plot numeric values, not text.
[2015-09-22 23:06:24] |
Yes this is true but they made reference to "text value". So we think they are referring to a numeric value.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 02:53:22
[2015-09-23 01:10:04] |
To clarify, I was referring to "text" as opposed to a numeric value from the spreadsheet cell. I cannot find a draw style to do this.
[2015-09-23 02:55:08] |
There is no support to take text from a Spreadsheet and display it as study Subgraphs. This is for performance reasons. Although you can use custom titles for the formula columns which display along the Region Data Line in the Chart Region were the Spreadsheet study is displayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 02:55:28
