Date/Time: Mon, 23 Dec 2024 08:07:21 +0000
new version
View Count: 705
[2015-09-22 00:30:45] |
User705641 - Posts: 38 |
I upgraded to ver 1296 however when I close the program and restart it reverts to ver 1261 what do I have to do to fix this issue please
[2015-09-22 04:57:57] |
This is not even technically possible what you describe. Also the current version is 1297 and here are update instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You may have multiple installations of Sierra Chart on your system and you are running a different one when you see version 1261. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
