Date/Time: Mon, 23 Dec 2024 08:14:16 +0000
Tool Values Window
View Count: 835
[2015-09-22 00:28:12]
tellerbe - Posts: 109
I have misplaced the button for the Tool Values Window. Please help me locate it.
T. Ellerbee
[2015-09-22 00:32:30]
I should have said Chart Values Window.
[2015-09-22 04:48:09]
You can open this through the Window menu:
https://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html
And you can add a ToolBar button:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar
[2015-09-23 01:50:58]
I have the screen up that shows "Available Tool Bar Commands". I co not see the CVW button in the list of available commands.
[2015-09-23 07:44:02]
It is listed in and as: Available Tool Bar Commands >> Window >> Chart Values Window.
[2015-09-23 15:10:42]
I clicked "Chart Values Window" and I get a screen that says "Chart values for last displayed column' I'm looking for "Chart Values for Tools"
[2015-09-23 18:07:01]
This is called "Tool Values Window".
[2015-09-23 21:06:45]
which of the 11 exceptions does my question fall under? I definitely have a "Chart Values for Tools" window on one of my computers I have lost it on the other one. If you have changed, I would like to see the other one brought back.
[2015-09-25 18:21:06]
Select Windows >> Reset Windows.
And select Window >> Chart Values Window or Window >> Tool Values Window.
Date Time Of Last Edit: 2015-09-25 18:22:44
