Date/Time: Mon, 23 Dec 2024 07:56:23 +0000
I am Using NinjaTrader - How do I connect?
View Count: 2736
[2015-09-21 16:58:06]
User456125 - Posts: 16
I am Using NinjaTrader - How do I connect? It appears to use cqg. What Do I need to do?
[2015-09-21 18:45:50]
The instructions for this are documented here:
CQG Trading Platform Service
Your CQG account needs to support a CQG FIX connection and be authorized for Sierra Chart.
[2015-09-21 20:52:59]
So, if I understand this correctly; I must use my NinjaTrader CQG account (at cost of $30) or pay at least $94.50 to get realtime quotes. otherwise use historical data only data.
please confirm
[2015-09-21 20:57:07]
Yes, you must use your CQG account. The FIX connection is only about 10 or 15 USD per month.
Otherwise, you do have to pay 94.50USD per month for real-time data. Or just use the historical data only.
[2015-09-22 16:03:52]
I have just been informed that the CQG fix is turned on at NinjaTrader Brokerage/Dorman Clearing.
Please let me Know when I can Expect Realtime updates. I assume it will require a restart of SC.
[2015-09-22 17:25:18]
Select Global Settings >> Data/Trade Service Settings and make sure Allow Support for Sierra Chart Data Feeds is checked.
Follow through the CQG set up instructions here:
CQG Trading Platform Service: Setup Instructions
Do not enter the Username and Password at step 7.
You will be working with the standard CQG symbols in File >> Find Symbol and you can perform trading also from Sierra Chart.
[2015-09-22 18:27:28]
Still NOT getting live updates:
I have input my CQG passwd and User as per instructions and the Log is not showing any obvious errors. I have restarted and connected
LOG is here below
Chart #3 has tagged chart #8 for full recalculation. Chartbook: OpenTrader2.cht | 2015-09-22 11:15:21
Chart #8 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader2.cht | 2015-09-22 11:15:21
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ15. ID: 6 | 2015-09-22 11:18:56
Intraday data recording state for symbol F.US.EPZ15 is set to download 'Pending'. | 2015-09-22 11:18:56
HD Request # 5 | Downloading Intraday chart data for F.US.EPZ15 to the file F.US.EPZ15.scid. Service: cqg | 2015-09-22 11:18:56
Compressing file: C:\SierraChart\Data\F.US.EPZ15.scid. This may take a while. | 2015-09-22 11:18:56
HD Request # 5 | Download start Date-Time: 2015-03-20 11:18:56.000 | 2015-09-22 11:18:56
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2015-09-22 11:18:56
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-09-22 11:18:56
Socket (11) | Connected. | 2015-09-22 11:18:56
HD Request # 5 | Sending historical data logon request message. | 2015-09-22 11:18:56
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-03-20 11:18:56. Record interval: 1. Symbol: F.US.EPZ15 | 2015-09-22 11:18:56
HD Request # 5 | Decompressing data. | 2015-09-22 11:18:56
HD Request # 5 | Receiving Intraday data for F.US.EPZ15 starting at 2015-06-30 19:05:22 | 2015-09-22 11:18:56
HD Request # 5 | Timestamp of first Intraday data file record written: 2015-06-30 19:05:22 | 2015-09-22 11:18:56
Requesting market depth updates for: F.US.EPZ15 if supported. | 2015-09-22 11:18:59
Socket (11) | Shutdown and closed. | 2015-09-22 11:19:00
The network socket for historical data has been closed. | 2015-09-22 11:19:00
HD Request # 5 | Received 416707 records from 2015-06-30 19:05:22 to 2015-09-22 11:19:07 (83.7 days) and wrote 416707 records for F.US.EPZ15 | 2015-09-22 11:19:00
HD Request # 5 | Intraday download COMPLETE for F.US.EPZ15. Completion time: 4s. Unique request ID: 6 | 2015-09-22 11:19:00
Removed historical data download ID 6 | 2015-09-22 11:19:00
Real-time Intraday chart data file updates started for F.US.EPZ15 | 2015-09-22 11:19:00
Unsubscribed from market depth data for F.US.EPZ15 | 2015-09-22 11:19:44
[2015-09-22 18:38:00]
User has been called and problem resolved.
Allow Support for Sierra Chart Data Feeds needed to be enabled and a reconnect to the data feed.
Date Time Of Last Edit: 2015-09-22 18:38:19
